Select the realm where you want to want to add SIP per user CAC.
ORACLE(realm-config)# select
monthly-minutes—Enter the number of minutes allowed during a calendar month in this realm for SIP and H.323 calls. By default, this parameter is set to zero (0), which disabled monthly minutes-based CAC. You can enter a value as high as 71582788.
