PreviousNextJavaScript must be enabled to correctly display this content
Viewing Realm-Based CAC Data
Use the ACLI show monthly-minutes command to see the following information:
How many minutes are configured for a realm
How many of those are still available
How many calls have been rejected due to exceeding the limit
To view information about SIP per user CAC using the IP address mode:
In either User or Superuser mode, type
show monthly-minutes <realm-id>, a Space, and the IP address for which you want to view data. Then press Enter. The
<realm-id> is the realm identifier for. the realm identifier of the specific realm for which you want data
