Configuration Example
This section provides an example of a SIP manipulation configuration that shows MIME rules and MIME ISUP rules.
sip-manipulation
name manip
description
header-rule
name headerRule1
header-name Date
action add
comparison-type case-sensitive
msg-type reply
methods
match-value
new-value
element-rule
name elemRule1
parameter-name
type header-value
action add
match-val-type any
match-value
new-value "August 19, 1967"
mime-rule
name mimeRule1
Content-Type application/SDP
action manipulate
msg-type request
methods
match-value
new-value
mime-header
name mimeHeaderRule1
mime-header-name Content-Disposition
action add
match-value
new-value "signal; handling=required"
mime-isup-rule
name mimeRule1
content-type application/ISUP
action manipulate
msg-type request
methods INVITE
match-value
new-value
isup-spec {ansi00, itu-92}
isup-msg-type 0 (0-256 IAM, ACM, etc.)
mime-header
action add
match-value
new-value "signal; handling=optional"
isup-param-rule
name isupRule1
parameter-type # {0-256 specific type)
parameter-format {number-parameter, hex, binary, ascii, bcd}
action add
match-value
