Assigning SIP Response Code Maps to Session Agents To assign a SIP local response code map to a session agent: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal Type session-router and press Enter. ORACLE(configure)# session-router ORACLE(session-router)# Type session-agent and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters. ORACLE(session-router)# session-agent ORACLE(session-agent)# local-response-map—Enter the name of the configured SIP response map that you want to use for this session-agent and press Enter. ORACLE(session-agent)# local-response-map busy Save and activate your configuration.
