Assigning SIP Response Code Maps to SIP Interfaces To apply SIP response codes maps to a SIP interface: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal Type session-router and press Enter to access the signaling-level configuration elements. ORACLE(configure)# session-router ORACLE(session-router)# Type sip-interface and press Enter. ORACLE(session-router)# sip-interface ORACLE(sip-interface)# local-response-map—Enter the name of the configured SIP response map that you want to apply to this SIP interface for locally-generated SIP responses. This parameter is blank by default. Save and activate your configuration.
