PreviousNextJavaScript must be enabled to correctly display this content
Required Signaling Service Parameters
To configure nested realms, you need to set parameters in the realm configuration and in the configurations for the signaling protocols you want to use.
To configure H.323 stack parameters for nested realms:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
h323
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# h323ORACLE(h323)#
Type
h323-stacks and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
From this point, you can configure H.323 stack parameters. To view all h323-stack configuration parameters, enter a
? at the system prompt.
allow-anonymous—Enter the admission control of anonymous connections accepted and processed by this H.323 stack. The default is
all. The valid values are:
all—Allow all anonymous connections
agents-only—Only requests from session agents allowed
realm-prefix—Session agents and address matching relam prefix
