Disabling the Second Login Prompt Configuration You disable the second login prompt in the authentication configuration. To disable the second login prompt: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal ORACLE(configure)# Type security and press Enter. ORACLE(configure)# security ORACLE(security)# Type authentication and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters. ORACLE(security)# authentication ORACLE(authentication)# login-as-admin—Set this parameter to enabled if you want users to be logged automatically in Superuser (administrative) mode. The default for this parameter is disabled. Save and activate your configuration.
