PreviousNextJavaScript must be enabled to correctly display this content
Disabling the Second Login Prompt
With this feature enabled, the
Oracle logs you in as a Superuser (i.e., in administrative mode) regardless of your configured privilege level for either a Telnet or an SSH session. However, if you log via SSH, you still need to enter the password for local or RADIUS authentication.
