SIP-ISUP Configuration
To use this feature, you set up:
- sip-profile—Defines the redirection behavior
- sip-isup-profile—Defines the ISUP version to use when supporting SIP-T
You can then apply these profiles to realms, session agents, and SIP interfaces where you want this feature enabled.
The sip-profile configuration contains information that defines redirection behavior for the configuration where you apply it. You can set the redirection behavior to: none, isup, or redirection. You also uniquely identify the profile so that you can apply it by name in other configurations. This is a multiple-instance configuration, meaning that you can set up as many SIP profiles as needed.
To set up a SIP profile:
