SIP ISUP Profile Configuration
To set up a SIP ISUP profile:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-isup-profile
and press Enter.
ORACLE(session-router)# sip-isup-profile ORACLE(sip-isup-profile)#
- name—Enter the name of the SIP ISUP profile. You will use this name when you apply this profile to realms, session agents, and SIP interfaces. This parameter is required, and it has no default value.
- isup-version—Specify the ISUP version you want used in this profile in order to support SIP-T: ansi-2000 (default) or itu-99.
- Save your work.
