SIP-ISUP Configuration
When you want to enable this feature for a realm, session agent, or SIP interface, you configure the sip-profile and sip-isup-profile parameters with the name of the profile you want applied.
The sample here shows this feature being applied to a session agent, but the realm and SIP interface configurations also have the same two parameters you use to set up the feature.
To apply a SIP profile and a SIP ISUP profile to a session agent:
