Disable Advanced Logging - Command Line
Confirm that advanced logging is enabled by way of the AdvancedLogging.lua SPL-plugin.
You can disable advanced logging by way of the command line without affecting any
sip-advanced-logging that is enabled by way of the Configure Mode.
From the AdvancedLogging.lua SPL-plugin, run the
spl stop advanced-loggingcommand.
