Configuring Advanced Logging
From Configure mode, define
sip-advanced-logging
and
advanced-log-condition
. The criteria that you configure remaps the message logging and modifies the system configuration. You must save and activate the changes to the configuration.
When configuring multiple
configurations, note the following:
- The system evaluates each configuration individually in an OR relationship.
- The system evaluates all conditions and they must all match in an AND relationship.
