| Command |
Description |
spl set sip advanced-logging add-criteria |
Adds another set of matching criteria.
spl set sip advanced-logging log-label <label string> |
Any logs of requests that are matched will have the specified <label string> appended before each log message for easier searching.
spl set sip advanced-logging rate-count <match count> |
Sets the rate-limiting to log only <match count> number of matching requests per time window.
spl set sip advanced-logging rate-time <time window> |
Sets the rate-limiting time window in seconds.
spl set sip advanced-logging in-agent <session-agent> |
Adds to the current set of matching criteria that the request must come from the specified incoming session-agent hostname.
spl set sip advanced-logging in-realm <realm-id> |
Adds to the current set of matching criteria that the request must come from the specified incoming realm identifier. |
spl set sip advanced-logging request-type <method name> |
Adds to the current set of matching criteria that the request must be of the specified request method type, for example, INVITE and REGISTER.
spl set sip advanced-logging from-uri-host <FROM URI host portion> |
Adds to the current set of matching criteria that the request FROM headerURI host portion must match the specified value exactly. |
spl set sip advanced-logging from-uri-user <FROM URI username portion> |
Adds to the current set of matching criteria that the request FROM headerURI username portion must match the string and the specified value exactly.
spl set sip advanced-logging to-uri-host <TO URI host portion> |
Adds to the current set of matching criteria that the request TO headerURI host portion must match the string and the specified value exactly.
spl set sip advanced-logging to-uri-user <TO URI username portion> |
Adds to the current set of matching criteria that the request TO headerURI username portion must match the string and the specified value exactly.
spl set sip advanced-logging request-uri-host <RURI host portion> |
Adds to the current set of matching criteria that the request RURI headerURI host portion must match the string and the specified value exactly.
spl set sip advanced-logging request-uri-user <RURI username portion> |
Adds to the current set of matching criteria that the request RURI headerURI username portion must match the string and the specified value exactly.
spl set sip advanced-logging header <header-type> <header-value> |
Adds to the current set of matching criteria that the request must have a header of type <header-type> with a value of <header-value> with exact string matches.
