System TCP Keepalive Settings
You can configure the Oracle® Enterprise Session Border Controller to control TCP connections by setting:
- The amount of time the TCP connection is idle before the Oracle® Enterprise Session Border Controller starts sending keepalive messages to the remote peer
- The number of keepalive packets the Oracle® Enterprise Session Border Controller sends before terminating the TCP connection
If TCP keepalive fails, then the Oracle® Enterprise Session Border Controller will drop the call associated with that TCP connection.
In the ALCI, a configured set of network parameters appears as follows:
network-parameters
tcp-keepinit-timer 75
tcp-keepalive-count 4
tcp-keepalive-idle-timer 400
tcp-keepalive-interval-timer 75
tcp-keepalive-mode 0
Then you apply these on a per-interface basis. For example, the H.323 interface (stack) configuration allows you to enable or disabled use of the network parameters settings.
