SNMP Configuration Overview
- Configure the SNMP identification information. This step includes configuring the MIB system contact, name, and location parameters.
- Set the general SNMP parameters to enable or disable SNMP on the Oracle® Enterprise Session Border Controller. This step includes setting the switches that govern how the SNMP system responds to specified events.
- Set the syslog events. This step includes setting the parameters for handling SNMP monitoring syslog events, which can trigger SNMP syslog traps.
- Set SNMP communities. Configuration is separated into a unique configuration element.
- Set trap receivers. Configuration is separated into a unique configuration element.
