SNMP Configuration
To configure SNMP:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
system and press Enter to access the system-level configuration elements.
ORACLE(configure)# system
Type
system-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(system)# system-config ORACLE(system-config)#
From this point, you can set SNMP parameters. The following is an example what an SNMP configuration might look like. Parameters not described in this section are omitted below.
system-config mib-system-contact John Doe mib-system-name Test System mib-system-location Upstairs snmp-enabled enabled enable-snmp-auth-traps disabled enable-snmp-syslog-notify disabled enable-snmp-monitor-traps disabled enable-env-monitor-traps disabled snmp-syslog-his-table-length 1 snmp-syslog-level WARNING
