About MIME ISUP Manipulation
MIME ISUP manipulation supports performing HMR operations on SIP ISUP binary bodies, and is configured in the mime-isup-rule configuration. This configuration works the same way that the MIME rule configuration does and contains the same parameters for you to set, but it also includes additional parameters and a sub-configuration targeted specifically for ISUP application.
