Acme Packet 4600
Oracle Communications introduces the Acme Packet 4600 hardware platform for E-CZ7.3.0.
The Acme Packet 4600 supports the Oracle® Enterprise Session Border Controller. This platform is based on the Acme Packet 6300 architecture and features encryption and transcoding in a single system. Transcoding functionality can utilize up to twelve transcoding modules on the NIU. The encryption feature set relies on the SSM3 encryption module. The Acme Packet 4600 platform runs the 64-bit software image exclusively.
The NIU provides six media ports (for example, 4 x GbE and 2 x 10GbE) on a single NIU card. Simultaneous operations of the GbE and 10GbE media ports is unsupported.
The Acme Packet 4600 contains an 80GB or 400GB internally mounted SSD memory drive. The system employs the same file system as the Acme Packet 6x.0.0 platform that runs the E-CZ7.3.0. series software. The mounted partitions include the /boot partition (2GB), the /code partition (2GB) and the /opt partition. The /opt partition is intended for core dumps, log files, and CDRs.
The Acme Packet 4600 has five cooling fans mounted of the front on the chassis to maintain proper operating temperature. The chassis contains 1:1 fully redundant AC and DC power supplies and load share when both are powered on. The two power supplies also have integrated fans.
The Acme Packet 4600 FRU list consists of the following:
- Acme Packet 4600 Chassis w/Mainboard
- Acme Packet 4600 NIU
- Transcoding Module
- Signaling Security Module (a.k.a. Encryption SSM3)
- Solid State Drive (80GB SSD or 400GB SSD)
- AC-input 1100-watt Power Supply w/cabling
- DC-input 1100-watt Power Supply w/cabling
- Fan Pod
- System Air Filter
- SFP Module (1 GbE)
- SFP+ Module (10GbE)
