Acme Packet 4600 Physical Interfaces
The Acme Packet 4600 has one network interface unit (NIU) that contains all external interfaces, including console, alarm, network management and media interfaces.
WARNING:
Customers must use either the 2 x 10GbE ports or the 4 x GbE ports. Using both P4-P5 and P0-P3 is not supported.The following illustration shows the NIU labels and ports. These designations are an important point of reference when you set up the phy-interface configuration element.
The Acme Packet 4600 NIU contains the following ports (from left to right).
- Console—Provides serial access for administrative and maintenance purposes.
- Alarm—Dry contact alarm port.
- USB—The USB port is reserved for use by Oracle support employees, only.
- Mgmt 0–Mgmt 2—These 10/100/1000 Base-T Ethernet ports are used for EMS control, RADIUS accounting, CLI management, SNMP queries and traps, and other management functions.
- P4–P5—2 x 10GbE ports for signaling and media traffic.
- P0–P3—4 x GbE ports for signaling and media traffic.
The OID in ap-products.mib for the Acme Packet 4600 is 1.3.6.1.4.1.9148.1.1.3.
