Example 2 Manipulating the Request URI
For this manipulation rules, the Oracle® Enterprise Session Border Controller stores the URI parameter tgid in the Request URI. Then if the pattern rule matches, it adds a new header (x-customer-profile) with the a new header value tgid to the URI parameter in the request URI.
This is a sample of the configuration:
sip-manipulation
name CustomerTgid
header-rule
name ruriRegex
header-name request-uri
action store
comparison-type pattern-rule
match-value
msg-type request
new-value
methods INVITE
element-rule
name tgidParam
parameter-name tgid
type uri-param
action store
match-val-type any
match-value
new-value
header-rule
name addCustomer
header-name X-Customer-Profile
action add
match-value $ruriRegex.$tgidParam
msg-type request
new-value $ruriRegex.$tgidParam.$0
methods INVITE
header-rule
name delTgid
action manipulate
msg-type request
new-value
methods INVITE
element-rule
name tgidParam
parameter-name tgid
type uri-param
action delete-element
match-val-type any
comparison-type case-sensitive
match-value $ruriRegex.$tgidParam.$0
new-value
This is a sample of the result:
Request-Line: INVITE sip:service@192.168.200.60:5060 SIP/2.0
Message Header
Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK0g6plv3088h03acgh6c1.1
From: sipp <sip:sipp@192.168.1.60:5060>;tag=SDc1rg601-1
To: sut <sip:service@192.168.1.61:5060>
Call-ID: SDc1rg601-f125d8b0ec7985c378b04cab9f91cc09-06a3gu0
CSeq: 1 INVITE
Contact: <sip:sipp@192.168.200.61:5060;transport=udp>
Goodbye: Remove Me
Custom: This is my custom header
Display: sipp <sip:user@192.168.1.60:5060;up=abc>;hp=123
Params: sipp <sip:sipp1@192.168.1.60:5060>
Params: sipp <sip:sipp2@192.168.1.60:5060>
Edit: disp <sip:user@192.168.1.60:5060>
Max-Forwards: 69
Subject: Performance Test
Content-Type: application/sdp
Content-Length: 140
X-Customer-Profile: 123
