Example 3 Manipulating a Header
For this manipulation rule, the Oracle® Enterprise Session Border Controllerstores the pattern matches for the Custom header, and replaces the value of the Custom header with a combination of the stored matches and new content.
This is a sample of the configuration:
sip-manipulation
name modCustomHdr
header-rule
name customSearch
header-name Custom
action store
comparison-type pattern-rule
match-value (This is my )(.+)( header)
msg-type request
new-value
methods INVITE
header-rule
name customMod
header-name Custom
action manipulate
match-value $customSearch
msg-type request
new-value
methods INVITE
element-rule
name hdrVal
parameter-name hdrVal
type header-value
action replace
match-val-type any
comparison-type case-sensitive
match-value
new-value $customSearch.$1+edited+$customSearch.$3
This is a sample of the result:
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0
Message Header
Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK20q2s820boghbacgs6o0.1
From: sipp <sip:sipp@192.168.1.60:5060>;tag=SDe1ra601-1
To: sut <sip:service@192.168.1.61:5060>
Call-ID: SDe1ra601-4bb668e7ec9eeb92c783c78fd5b26586-06a3gu0
CSeq: 1 INVITE
Contact: <sip:sipp@192.168.200.61:5060;transport=udp>
Goodbye: Remove Me
Custom: This is my edited header
Display: sipp <sip:user@192.168.1.60:5060;up=abc>;hp=123
Params: sipp <sip:sipp1@192.168.1.60:5060>
Params: sipp <sip:sipp2@192.168.1.60:5060>
Edit: disp <sip:user@192.168.1.60:5060>
Max-Forwards: 69
Subject: Performance Test
Content-Type: application/sdp
Content-Length: 140
