Example 4 Storing and Using URI Parameters
For this manipulation rule, the Oracle® Enterprise Session Border Controller stores the value of the URI parameter tag from the From header. It also creates a new header FromTag with the header value from the stored information resulting from the first rule.
This is a sample of the configuration:
sip-manipulation
name storeElemParam
header-rule
name Frohmr
header-name From
action store
comparison-type case-sensitive
match-value
msg-type request
new-value
methods INVITE
element-rule
name elementRule
parameter-name tag
type uri-param
action store
match-val-type any
match-value
new-value
header-rule
name newHeader
header-name FromTag
action add
comparison-type pattern-rule
match-value $FromHR.$elementRule
msg-type any
new-value $FromHR.$elementRule.$0
methods
This is a sample of the result:
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0
Message Header
Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK4oda2e2050ih7acgh6c1.1
From: sipp <sip:sipp@192.168.1.60:5060>;tag=SDf1re601-1
To: sut <sip:service@192.168.1.61:5060>
Call-ID: SDf1re601-f85059e74e1b443499587dd2dee504c2-06a3gu0
CSeq: 1 INVITE
Contact: <sip:sipp@192.168.200.61:5060;transport=udp>
Goodbye: Remove Me
Custom: This is my custom header
Display: sipp <sip:user@192.168.1.60:5060;up=abc>;hp=123
Params: sipp <sip:sipp1@192.168.1.60:5060>
Params: sipp <sip:sipp2@192.168.1.60:5060>
Edit: disp <sip:user@192.168.1.60:5060>
Max-Forwards: 69
Subject: Performance Test
Content-Type: application/sdp
Content-Length: 140
FromTag: 1
