Example 5 Manipulating Display Names
For this manipulation rule, the Oracle® Enterprise Session Border Controller sores the display name from the Display header. It replaces the two middle characters of the original display name with a new string. Then is also replaces the From header’s display name with “abc 123” if it matches sipp.
This is a sample of the configuration:
sip-manipulation
name modDisplayParam
header-rule
name storeDisplay
header-name Display
action store
comparison-type case-sensitive
match-value
msg-type request
new-value
methods INVITE
element-rule
name displayName
parameter-name display
type uri-display
action store
match-val-type any
comparison-type pattern-rule
match-value (s)(ip)(p )
new-value
header-rule
name modDisplay
header-name Display
action manipulate
match-value
msg-type request
new-value
methods INVITE
element-rule
name modRule
type uri-display
action replace
match-val-type any
match-value $storeDisplay.$displayName
new-value $storeDisplay.$displayName.$1+lur+$storeDisplay.$displayName.$3
header-rule
name modFrom
header-name From
action manipulate
match-value
msg-type request
new-value
methods INVITE
element-rule
name fromDisplay
parameter-name
type uri-display
action replace
match-val-type any
match-value sipp
new-value "\"abc 123\" "
This is a sample of the result:
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0
Message Header
Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK681kot109gp04acgs6o0.1
From: "abc 123" <sip:sipp@192.168.1.60:5060>;tag=SD79ra601-1
To: sut <sip:service@192.168.1.61:5060>
Call-ID: SD79ra601-a487f1259e2370d3dbb558c742d3f8c4-06a3gu0
CSeq: 1 INVITE
Contact: <sip:sipp@192.168.200.61:5060;transport=udp>
Goodbye: Remove Me
Custom: This is my custom header
Display: slurp <sip:user@192.168.1.60:5060;up=abc>;hp=123
Params: sipp <sip:sipp1@192.168.1.60:5060>
Params: sipp <sip:sipp2@192.168.1.60:5060>
Edit: disp <sip:user@192.168.1.60:5060>
Max-Forwards: 69
Subject: Performance Test
Content-Type: application/sdp
Content-Length: 140
