Example 6 Manipulating Element Parameters
For this more complex manipulation rule, the Oracle® Enterprise Session Border Controller:
- From the Display header, stores the display name, user name, URI parameter up, and header parameter hp
- Adds the header parameter display to the Params header, with the stored value of the display name from the first step
- Add the URI parameter user to the Params header, with the stored value of the display name from the first step
- If the URI parameter match succeeds in the first step, replaces the URI parameter up with the Display header with the value def
- If the header parameter match succeeds in the first step, deletes the header parameter hp from the Display header
This is a sample of the configuration:
sip-manipulation
name elemParams
header-rule
name StoreDisplay
header-name Display
action store
comparison-type case-sensitive
match-value
msg-type request
new-value
methods INVITE
element-rule
name displayName
parameter-name
type uri-display
action store
match-val-type any
comparison-type pattern-rule
match-value
new-value
element-rule
name userName
parameter-name user
type uri-user
action store
match-val-type any
match-value
new-value
element-rule
name uriParam
parameter-name up
type uri-param
action store
match-val-type any
match-value
new-value
element-rule
name headerParam
parameter-name hp
type header-param
action store
match-val-type any
match-value
new-value
header-rule
name EditParams
header-name Params
action manipulate
match-value
msg-type request
new-value
methods INVITE
element-rule
name addHeaderParam
parameter-name display
type header-param
action add
match-val-type any
match-value
new-value $StoreDisplay.$displayName.$0
element-rule
name addUriParam
parameter-name user
type uri-param
action add
match-val-type any
match-value
new-value
$StoreDisplay.$userName.$0
header-rule
name EditDisplay
header-name Display
action manipulate
match-value
msg-type request
new-value
methods INVITE
element-rule
name replaceUriParam
parameter-name up
type uri-param
action replace
match-val-type any
match-value $StoreDisplay.$uriParam
new-value def
element-rule
name delHeaderParam
parameter-name hp
type header-param
action delete-element
match-val-type any
match-value $StoreDisplay.$headerParam
new-value
This is a sample of the result:
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0
Message Header
Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK7okvei0028jgdacgh6c1.1
From: sipp <sip:sipp@192.168.1.60:5060>;tag=SD89rm601-1
To: sut <sip:service@192.168.1.61:5060>
Call-ID: SD89rm601-b5b746cef19d0154cb1f342cb04ec3cb-06a3gu0
CSeq: 1 INVITE
Contact: <sip:sipp@192.168.200.61:5060;transport=udp>
Goodbye: Remove Me
Custom: This is my custom header
Display: sipp <sip:user@192.168.1.60:5060;up=def>
Params: sipp <sip:sipp1@192.168.1.60:5060;user=user>;display=sipp
Params: sipp <sip:sipp2@192.168.1.60:5060;user=user>;display=sipp
Edit: disp <sip:user@192.168.1.60:5060>
Max-Forwards: 69
Subject: Performance Test
Content-Type: application/sdp
Content-Length: 140
