PreviousNextJavaScript must be enabled to correctly display this content
Applying the Local Routing Configuration
Apply the local routing configuration by calling it to use in the local policy attributes. You do this by setting a flag in the next-hop parameter along with the name of the local routing configuration that you want to use.
To apply the local routing configuration:
In Superuser mode, type
configure terminal, and press Enter.
next-hop—In the
next-hop parameter, type in
lrt: followed directly by the name of the local routing configuration to be used. The
lrt: tag tells the
Oracle® Enterprise Session Border Controller that a local route table will be used.
