RTC Notes
Starting in Release 4.1, the HA configuration is supported for real-time configuration (RTC). However, not all of the HA-related parameters are covered by RTC because of the impact on service it would cause to reconfigure these parameters dynamically.
This section sets out what parameters you should not dynamically reconfigure, or should dynamically reconfigure with care.
