Setting the Minimum Signal Duration
To configure the minimum signal duration value:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
media-manager and press Enter.
ORACLE(configure)# media-manager
Type
media-profile
and press Enter.
ORACLE(media-manager)# media-manager ORACLE(media-manager-config)#
options—Set the options parameter by typing
options, a Space, the option name
min-signal-duration=x (where
x
is the value in milliseconds you want to use for the threshold) with a plus sign in front of it. Then press Enter.
ORACLE(media-manager-config)# options +min-signal-duration=200
If you type options and then the option value for either of these entries without the plus sign, you will overwrite any previously configured options. In order to append the new option to the configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
- Save and activate your configuration.
