rfc-2833-timestamp—Enable this parameter to use a timestamp value calculated using the actual time elapsed since the last RTP packet. The default is
disabled. Valid values are:
enabled | disabled
Save and activate your configuration.
To configure a duration for the 2833 event:
In Superuser mode, type
configure terminal and press Enter.
default-2833-duration—Set this parameter to the time value in milliseconds for the
Oracle® Enterprise Session Border Controller to use when it receives an alphanumeric UII or a SIP INFO with no specified duration; then the three end-event packets are sent. The default value is 100. The valid range is:
