Configuring Overload Protection for Session Agents
The Oracle® Enterprise Session Border Controller offers two methods to control SIP registrations to smooth the registration flow.
You can limit the:
- number of new register requests sent to a session agent (using the max-register-sustain-rate parameter)
- burstiness which can be associated with SIP registrations
The first method guards against the Oracle® Enterprise Session Border Controller’s becoming overwhelmed with register requests, while the second method guards against a transient registration that can require more than available registration resources.
SIP registration burst rate control allows you to configure two new parameters per SIP session agent—one that controls the registration burst rate to limit the number of new registration requests, and a second to set the time window for that burst rate. When the registration rate exceeds the burst rate you set, the Oracle® Enterprise Session Border Controller responds to new registration requests with 503 Service Unavailable messages.
Note that this constraint is not applied to re-registers resulting from a 401 Unauthorized challenge request.
To configure overload protection for session agents:
