PreviousNextJavaScript must be enabled to correctly display this content
Configuring Static Flows
This section explains how to configure static flows. It also provides sample configurations for your reference. You can configure static flows with or without NAT ALG. If you configure static flows with NAT ALG, you can choose NAPT or TFTP as the ALG type.
