Authorization RESPONSE Packet
The TACACS+ daemon sends an authorization RESPONSE packet to the Oracle® Enterprise Session Border Controller to report authorization results.
The authorization RESPONSE packet format is as follows.
+-----------------------------------+ | Common Header | | | | type contains 0x2 | +--------+--------+-----------------+ |status |arg_cnt | server_msg len | | | | | |--------+--------+--------+--------+ | data_len |arg1_len|arg2_len| | | | | +--------+--------+--------+--------+ | ... |argN_len| server_msg | | | | | +--------+--------+-----------------+ | data ... | +-----------------------------------+ | arg1 ... | +-----------------------------------+ | arg2 ... | +-----------------------------------+ | argN ... | +-----------------------------------+
status
This 8-bit field contains an enumerated value that specifies the results of the authorization process. Supported values are 0x01 (Pass), 0x10 (Fail), and 0x11 (Error). Fail indicates that the authorization service rejected the proposed operation, while Error indicates the authorization service failed
If authorization succeeds (status=0x01), the ACLI command is executed; if authorization fails, for whatever the reason (status=0x10 or 0x11), the ACLI command is not executed, and an appropriate error message is generated.
arg_cnt
This 8-bit field contains an integer that specifies the number or arguments contained with the RESPONSE. Given the design of the current TACACS+ implementation, this field always contains a value of 0x02 .
server_msg_len
This 16-bit field contains an integer that specifies the length, in octets, of the server_msg field.
data_len
This 16-bit field contains an integer that specifies the length, in octets, of the data field.
arg1_len
This 8-bit field contains an integer that specifies the length, in octets, of the first argument.
Subsequent fields contain the length of each sequential argument.
server-msg
This optional variable length field contains a string that can be presented to the user.
data
This optional variable length field contains a string that can be presented to an administrative display, console, or log.
arg...
This optional variable length field contains a TACACS+ attribute value pair (AVP); each arg field holds a single AVP.
No arguments are generated in RESPONSE packets within the current TACACS+ implementation.
