Authorization REQUEST Packet
The Oracle® Enterprise Session Border Controller, acting as a TACACS+ client, sends an authorization REQUEST packet to the TACACS+ daemon to initiate an authorization session.
The authorization REQUEST packet format is as follows.
+-----------------------------------+ | Common Header | | | | type contains 0x2 | +--------+--------+--------+--------+ |authen_ |priv_lvl|authen_ |authen- | |method | |type |service | |--------+--------+--------+--------+ |user_len|port_len|rem_addr|arg_cnt | | | |_len | | +----+---+--------+--------+--------+ |arg1_len|arg2_len| ... |argN_len| | | | | | +--------+--------+--------+--------+ | user ... | +-----------------------------------+ | port ... | +-----------------------------------+ | rem-addr ... | +-----------------------------------+ | arg1 ... | +-----------------------------------+ | arg2 ... | +-----------------------------------+ | argN ... | +-----------------------------------+
authen_method
This 8-bit field contains an enumerated value that identifies the method used to authenticate the authorization subject — that is, an admin user. Because the admin user was authenticated locally by the Oracle® Enterprise Session Border Controller, this field always contains a value of 0x05 , indicating authentication by the requesting client.
priv_lvl
This 8-bit field contains an enumerated value that identifies the privilege level associated with the authorization subject. For the current TACACS+ authorization implementation, this field always contains a value of 0x00 .
authen-type
This 8-bit field contains an enumerated value that identifies the methodology. used to authenticate the authorization subject. Because the admin user was authenticated with a simple username/password exchange, this field always contains a value of 0x01 , indicating ascii login.
authen_service
This 8-bit field contains an enumerated value that identifies the service that requested authentication. Because an admin user is authenticated with a simple username/password exchange, this field always contains a value of 0x01 , the login service.
user_len
This 8-bit field contains an integer that specifies the length, in octets, of the user field.
port_len
This 8-bit field contains an integer that specifies the length, in octets, of the port field.
rem_addr_len
This 8-bit field contains an integer that specifies the length, in octets, of the rem_addr field.
arg_cnt
This 8-bit field contains an integer that specifies the number or arguments contained with the REQUEST. Given the design of the current TACACS+ implementation, this field always contains a value of 0x02 .
arg1_len
This 8-bit field contains an integer that specifies the length, in octets, of the first argument.
Subsequent fields contain the length of each sequential argument.
user
This variable length field contains the login name of the user to be authorized.
port
This variable length field contains the name of the Oracle® Enterprise Session Border Controller port on which authorization is taking place. Following Cisco Systems convention, this field contains the string tty10 .
rem_addr
This variable length contains the location of the user to be authorized. This field contains the localhost address.
arg...
This variable length field contains a TACACS+ attribute value pair (AVP); each arg field holds a single AVP.
A TACACS+ AVP is an ASCII string with a maximum length of 255 octets. The string consists of the attribute name and its assigned value separated by either an equal sign (=) or by an asterisk (*). The equal sign (=) identifies a mandatory argument, one that must be understood and processed by the TACACS+ daemon; the asterisk (*) identifies an optional argument that may be disregarded by either the client or daemon.
Administrative authorization requires the use of only two TACACS+ AVPs: service and cmd .
The service AVP identifies the function to be authorized. In the case of the current implementation, the attribute value is always shell . Consequently the attribute takes the follow format:
service=shell
The cmd AVP identifies the specific ACLI command to be authorized. The command is passed in its entirety, from the administrative configuration root, configure terminal, through the final command argument. For example,
cmd=configure terminal security authentication type tacacsplus
Note the equal sign (=) used in the attribute examples, indicating that both are mandatory arguments.
