Global H.323 Settings
To configure global H.323 parameters:
state—Enable or disable the state of H.323 signaling. The default value is
enabled. Valid values are:
enabled | disabled
response-tmo—Enter the amount of time in seconds that the
Oracle® Enterprise Session Border Controller waits between sending a Setup message and tearing it down if there is no response. The default value is
4 and we recommend you leave this parameter set to this value. The valid range is:
Minimum—0
Maximum—999999999
A response might be any of the following messages: Call Proceeding, Connect, or Alerting.
connect-tmo—Enter the amount of time in seconds that the
Oracle® Enterprise Session Border Controller waits between sending a Setup message and tearing it down if it does not specifically receive a Connect message from the endpoint. The default is
32 and we recommend that you leave this parameter set to this value. The valid range is:
Minimum—0
Maximum—999999999
Receiving a Proceeding or Alert message from the endpoint does not keep this timer from expiring.
options—Set any options for H.323 features that you want to use. This parameter has a global impact on H.323 behavior, rather that being applied on a per-interface basis.
If you do not configure options for global H.323 behavior, none appears in the configuration display.
log-level—Set the process log level for monitoring all H.323 activity on the
Oracle® Enterprise Session Border Controller. The default is
INFO and leaving this parameter set to this value provides an intermediate amount of detail in the logs. Other valid values are:
Any log level you set here overrides the log level you set in the system configuration’s process log level parameter.Numerical Code Acme Packet Log Enumeration Description 1 EMERGENCY Logs conditions of the utmost severity that require immediate attention. 2 CRITICAL Logs events of serious condition that require attention as soon as possible. 3 MAJOR Logs conditions indicating that functionality is seriously compromised. 4 MINOR Logs conditions indicating that functionality has been impaired in a minor way. 5 WARNING Logs conditions indicating irregularities in performance. 6 7
8
9
NOTICE INFO
TRACE
DEBUG
For Acme Packet customer support.
