PreviousNextJavaScript must be enabled to correctly display this content
Accessing Global H.323 Parameters
To access the global H.323 configuration parameters in the ACLI:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session-related configurations.
ORACLE(configure)# session-router
Type
h323
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# h323
From this point, you can configure global H.323 parameters. To view all H.323 configuration parameters, enter a
? at the system prompt. Access to the H.323 interface (h323-stack) configuration also appears.
