show mbcd errors
The show mbcd errors command displays statistics related to MBCD task errors. The following fields are explained:
- XCode Internal Errors—Number of uncategorized errors due to Transcoding session error.
- XCode Alloc Errors—Number of times that buffer allocation failed for transcoding tasks.
- XCode Update Errors—Number of errors encountered when attempting to update an entry in the Transcoding table upon receipt of the first packet for a media flow.
- XCode Delete Errors—Number of errors encountered when attempting to delete an entry in the Transcoding table.
- XCode Over Cap Errors—Number of Transcoding sessions denied once session capacity is reached.
- XCode Over License Cap—Number of Transcoding sessions denied once license capacity is reached.
ORACLE# show mbcd errors 13:22:50-126 MBC Errors/Events ---- Lifetime ---- Recent Total PerMax Client Errors 0 0 0 Client IPC Errors 0 0 0 Open Streams Failed 0 0 0 Drop Streams Failed 0 0 0 Exp Flow Events 0 0 0 Exp Flow Not Found 0 0 0 Transaction Timeouts 0 0 0 Server Errors 0 0 0 Server IPC Errors 0 0 0 Flow Add Failed 180 180 180 Flow Delete Failed 0 0 0 Flow Update Failed 0 0 0 Flow Latch Failed 0 0 0 Pending Flow Expired 0 0 0 ARP Wait Errors 0 0 0 Exp CAM Not Found 0 0 0 Drop Unknown Exp Flow 0 0 0 Drop/Exp Flow Missing 0 0 0 Exp Notify Failed 0 0 0 Unacknowledged Notify 0 0 0 Invalid Realm 0 0 0 No Ports Available 0 0 0 Insufficient Bandwidth 0 0 0 Stale Ports Reclaimed 0 0 0 Stale Flows Replaced 0 0 0 Telephone Events Gen 0 0 0 Pipe Alloc Errors 0 0 0 Pipe Write Errors 0 0 0 Not Found In Flows 0 0 0 XCode Internal Errors 0 0 0 XCode Alloc Errors 0 0 0 XCode Update Errors 0 0 0 XCode Delete Errors 0 0 0 XCode Over Cap Errors 180 180 180 XCode Over License Cap 0 0 0 SRTP Capacity Exceeded 0 0 0
