Export an E-SBC Configuration to a CSV File
You can export an existing configuration from the Oracle® Enterprise Session Border Controller (E-SBC )to a CSV file using the following command:
spl save acli config-csv <filename>
This command saves the editing configuration on the E-SBC to a CSV file with the filename that you specify, and stores it on the volatile file system (/ramdrv/ for 4500), (/var/ for E-SBC).
