Import ACLI Command
After you create a CSV file that contains your Oracle® Enterprise Session Border Controller (E-SBC) configuration, you can import the file into the E-SBC using the following command:
spl load acli config-csv <filename>
This command loads the CSV file from the volatile file system (/ramdrv/ for 4500), (/var/ for NN-ESD), into the editing configuration of the E-SBC.
Before You Begin- You must have a CSV file already created that contains the new configuration data that you want to import.
- Initiate the delete-config cached command to clear the current editing configuration before importing to prevent conflicts.
