Number Translation Application
To complete your number translation configuration, you must enter into a realm-config or session-agent element and assign session-translations there.
Navigate to the chosen element.
To move from the session-translation element to the session-agent element, exit out of the session translation element and enter the session agent element.
ORACLE(session-translation)# exit ORACLE(session-router)# session-agent ORACLE(session-agent)#
To move from the session-translation element to the realm-config element, exit from the session translation element to the configuration path.
ORACLE(session-translation)# exit ORACLE(session-router)# exit
Navigate to the ream-config element located in the media-manager path.
ORACLE(configure)# media-manager ORACLE(media-manager)# realm-config ORACLE(realm-config)#
In both
realm-config or
session agent elements, you must specify an
in-translationid and/or an
out-translationid in order to configure the number translation.
session-agent in-translationid out-translationid lrules-out realm-config in-translationid out-translationid lrules-out
Set the following parameters to configure a translation rule:
- in-translationid—Enter the configured session translation that you want to affect the incoming traffic in this parameter.
- out-translationid—Enter the configured session translation that you want to affect the outgoing traffic in this parameter.
