Session Translation
To configure session translations:
Exit out of the translation rules element and enter the session translation element.
ORACLE(translation-rules)# exit ORACLE(session-router)# session-translation ORACLE(session-translation)#
From this point, you can configure the session translation element. To view all session translation parameters, enter a ? at the system prompt. The following is an example of what a session translation configuration might look like:
session-translation id lrules-out rules-calling rule1 rule2 rule3 rules-called addplus1 - ID—Set a descriptive ID name for this session translation.
rules-calling—Enter the rules calling in the order in which they should be applied. Multiple rules should be included in quotes and separated by spaces.
ORACLE(session-translation)# rules-calling "rule1 rule2 rule3"
- rules-called—Enter the rules called in the order in which they should be applied. Multiple rules should be included in quotes and separated by spaces.
