H.323-TCS Generic Audio Configuration
To set a media profile for generic audio support:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
media-profile
and press Enter.
ORACLE(session-router)# media-profile ORACLE(media-profile)#
- name—Set the name of the generic audio media profile to genericAudio. There is no default for this parameter.
- media-type—Set the media type to use for this media profile; for generic video, set this parameter to audio.
- payload-type—Enter the format in SDP m lines. No payload type number is assigned for newer, dynamic codecs. For RTP/AVP media-profile elements, this field should only be configured when there is a standard payload type number that corresponds to the encoding name. Otherwise, this field should be left blank. This field is used by the system to determine the encoding type when the SDP included with a session identifies the standard payload type on the em line, but does not include an a-rtpmap entry.
transport—Set the type of transport protocol to use for the generic audio media profile. The default value is
RTP/AVP.
UPD | RTP/AVP
- Complete the rest of the media profile configuration as needed.
Save and activate your configuration.
The following is a sample of a generic audio media profile configuration:
media-profile name genericAudio media-type audio payload-type 104 transport RTP/AVP req-bandwidth 0 frames-per-packet 0 parameters average-rate-limit 0 sdp-rate-limit-headroom 0 sdp-bandwidth disabled
