Realm Configuration
To access the realm configuration parameters in the ACLI:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager
and press Enter to access the media-related configurations.
ORACLE(configure)# media-manager
Type
realm-config
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# realm-config ORACLE(realm-config)#
From this point, you can configure realm parameters. To view all realm configuration parameters, enter a ? at the system prompt.
