Before You Configure
Before you configure realms, you want to establish the phy and network interfaces with which the realm will be associated.
- Configure a phy-interface to define the physical characteristics of the signaling line.
- Configure a network-interface to define the network in which this realm is participating and optionally to create VLANs.
If you wish to use QoS, you should also determine if your Oracle® Enterprise Session Border Controller is QoS enabled.
Remember that you will also use this realm in other configurations to accomplish the following:
- Set a signaling port or ports at which the Oracle® Enterprise Session Border Controller listens for signaling messages.
- Configure sessions agents to point to ingress and egress signaling devices located in this realm in order to apply constraint for admission control.
- Configure session agents for defining trusted sources for accepting signaling messages.
