Egress Offer Format for SDES Profile Configuration
To set the egress offer format for an SDES profile configuration:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
security and press Enter.
ORACLE(configure)# security ORACLE(security)#
Type
media-security
and press Enter.
ORACLE(security)# media-security ORACLE(media-security)#
Type
sdes-profile
and press Enter. If you are editing a pre-existing configuration, you needs to select it before you can make changes.
ORACLE(media-security)# sdes-profile ORACLE(sdes-profile)#
egress-offer-format—Choose an egress offer format for this profile to use when you set the outbound mode in the media security policy to
any. You can select one of two values:
If the value is same-as-ingress (default), the E-SBC leaves the profile of the media lines unchanged.
If the value is simultaneous-best-effort, the E-SBC inspects the incoming offer SDP and:
- Adds an RTP/SAVP media line for any media profile that has only the RTP/AVP media profile
- Adds an RTP/AVP media line for any media profile that has only the RTP/SAVP media profile
Type done
to save your work and continue.
Type
Type
media-security
and press Enter.
- Type done to save your work and continue.
