ACLI Instructions and Examples
This section shows you how to configure your E-SBC to support secure and non-secure flows in the same realm.
To configure a security policy to support secure and non-secure flows in the same realm:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
security and press Enter.
ORACLE(configure)# security ORACLE(security)#
Type
media-security
and press Enter.
ORACLE(security)# media-security ORACLE(media-security)#
Type
media-sec-policy
and press Enter. If you are editing a pre-existing configuration, you needs to select it before you can make changes.
ORACLE(media-security)# media-sec-policy ORACLE(media-sec-policy)#
Type
inbound to enter the setting for inbound flows.
ORACLE(media-sec-policy)# inbound ORACLE(inbound)#
- mode—Enter the mode that you want to use for inbound flows. You can choose from rtp, srtp, and any. Refer to the For Incoming Flows (1082) section Mode Settings in the Media Security Policy (1082) description for details about each value.
- protocol—Change this value to none. Use the done command to save your work, and exit the inbound configuration.
Type
outbound to enter the setting for inbound flows.
ORACLE(media-sec-policy)# outbound ORACLE(outbound)#
- mode—Enter the mode that you want to use for outbound flows. You can choose from rtp, srtp, and any. Refer to the For Outgoing Flows (1082) section Mode Settings in the Media Security Policy (1082) description for details about each value.
- protocol—Change this value from to none. Use the done command to save your work, and exit the outbound configuration.
- Type done and continue.
