Bandwidth CAC Configuration
To enable bandwidth CAC for media release:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
realm-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# realm-config ORACLE(realm-config)#
Select the realm where you want to want to add this feature.
ORACLE(realm-config)# select
bw-cac-non-mm—Enable this parameter to turn on bandwidth CAC for media release. The default is
disabled. The valid values are:
enabled | disabled
- Save and activate your configuration.
