Media Release between Endpoints with the Same IP Address
You can configure your Oracle® Enterprise Session Border Controller to release media between two endpoints even when one of them:
- Is directly addressable at the same IP address as a NAT device, but is not behind a NAT device
- Is at the same IP address of a NAT device the other endpoint is behind
You enable this feature on a per-realm basis by setting an option in the realm configuration.
When this option is not set, theOracle® Enterprise Session Border Controller will (when configured to do so) release media between two endpoints sharing one NAT IP address in the same realm or network.
