Media Release Configuration
In order for this feature to work properly, the following conditions apply for the realm configuration:
- Either the mm-in-realm or the mm-in-network parameter must be disabled; you can have one of these enabled as long as the other is not. The new option will apply to the parameter that is disabled.
- If either the mm-in-realm or mm-in-network parameter is enabled, then the mm-same-ip parameter must be disabled.
To enable media release between endpoints with the same IP address:
