max-bandwidth—Enter a number that sets the maximum bandwidth for dynamic flows to/from the realm in kilobits (Kbps) per second. The default value is zero (0). The valid range is:
Minimum—0
Maximum—4294967295
The following example shows the maximum bandwidth for the realm has been configured. All other realm parameters have been omitted for brevity.
