SIP Admission Control Configuration
You can configure the registered endpoint to accept and process requests from SIP realms. If a request does not meet the criteria of the option you choose here, it is rejected with a 403 (Forbidden) response.
To configure admission control:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
sip-interface
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
Type
sip-ports
ORACLE(sip-interface)# sip-port ORACLE(sip-port)#
Set the criteria for admission control.
allow-anonymous—Enter the anonymous connection mode you want applied when SIP requests are processed. The default value is all.
The following are valid values:
all—No ACL is applied and all anonymous connections are allowed.
agents-only—Only requests from configured session agents are processed. The Oracle® Enterprise Session Border Controller responds to all other requests with a forbidden response.
realm-prefix—Only requests from session agents and addresses matching the realm’s address prefix are processed. All other requests are rejected with a 403 (Forbidden) response.
registered—Only requests from session agents and registered endpoints are processed. REGISTER allowed from any endpoint.
registered-prefix—Only requests from session agent and registered endpoint addresses that match the realm’s realm prefix are processed.
The following example shows the allow-anonymous parameter that has been configured to allow only requests from session agents and registered endpoints. All other session agent parameters following the allow-anonymous parameters are omitted for brevity.
sip-port address port 5060 transport-protocol UDP allow-anonymous registered
